A/C help Please!!!!
Old Sep 22, 2000 | 11:18 PM
Iroc_Z28's Avatar
A/C help Please!!!!
i have a problem with my a/c on my camaro for some reason it will only blow out the defrost..no matter what i put it on ...oh and it worked great till a cpl of days ago..could have i done something while taking the smog pump off that would cause this problem....any help is appericated...
Old Sep 23, 2000 | 08:19 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Sounds like you knocked off the vacuum line that supplies the HVAC controls. If you have TPI, it is on the passenger side, and connnects to the rear of the intake plenum. Or, you may have knocked something off elsewhere, in any case, a vacuum leak will prevent the controls from working correctly.
Defrost is the default position.
Old Oct 31, 2001 | 08:14 AM
IRC4FRE's Avatar
I have the same problem. My Vacuum line is hooked up to the phlenum but cannot find any diagrams to show where they go from there. I know they go down to the cannister but where do they go into trhe dash. Does anyone have any diagrams or know where I can go look
Old Nov 5, 2001 | 02:50 PM
prowler's Avatar
What type of pulleys are you running?
Old Nov 5, 2001 | 04:12 PM
Enkil's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IRC4FRE:
I have the same problem. My Vacuum line is hooked up to the phlenum but cannot find any diagrams to show where they go from there. I know they go down to the cannister but where do they go into trhe dash. Does anyone have any diagrams or know where I can go look</font>
Take out the controls for the heater/ac. The vacuum lines run into the back of that.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
