Stroking my 350...
Old Sep 27, 2005 | 09:58 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Stroking my 350...
Well i dont have the rotating assembly yet, im thinking of an eagle kit w/ 5.7" rods.
Im new to the whole stroking thing and wondering what all needs to be clearanced in the block to get this thing in there?
Ive done a few searches and didnt come up with much, anyone got pics of whats been clearanced?
Old Sep 28, 2005 | 04:58 AM
ede's Avatar
ede
depends on the rods, or rod bolts, but as a rule you'll need to remove metal around the oil pan rail and maybe the bottom of the cylinders. filling a inch or so of the block with grout will help in case you hit "water". a small base circle cam will help and rods that use cap screws will help you out a lot
Old Sep 28, 2005 | 09:38 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
So theirs not many different spots that need grinding then i guess, that doesnt seem too bad as long as i dont have to gring 20lbs of metal out of the block
Hehe, i could just see the look on my face right now when i fire it up and my block instantly fills with water...
For the compression ratio, think i could get away with 9.5:1 on cast heads on 91octane?
Old Sep 28, 2005 | 09:47 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
if you wanna talk to a really good source PM thebigwelsh.
He is building my 383 to hold 500 HP N/A. It is gonna be a screamer and internally balanced.
He is making out of a 79 tuck, solid camed block, and converting it to a roller cam. (this is gonna be a street motor, lol)
He will help you out, or build you a short block for less than you can build it.
He is giving me a KILLER deal on mine, full motor.
junior419
Apr 7, 2025 11:35 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
C409
Sep 23, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
