Converting L98 to carb seeking 300rwhp... suggestions please!
Old Sep 28, 2005 | 04:09 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
ok I have an L98 motor (TPI 350) in my Iroc right nowe and I am having nothing but problems. I decided it's time to ditch the TPI and go carb.
Here is my main question; Whats the eisiest way to see 300rwhp n/a using the stock bottom end?
I am also going to be spraying this motor. I know the bottom end is not going to last me too long so I don't need the heads up on that
I do how ever plan on using a proform 750cfm carb with a victor jr. intake. anyone else for any advice?
Price is a huge concern, I am on a budget but want to race!!!
Old Sep 28, 2005 | 06:25 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
whats your budget? Vortec heads and a mild cam around 220* will make good enough power and thats about as budget as you're gonna get. . Also that's probably not the best intake for what you want to do
Old Sep 28, 2005 | 06:42 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
I don't want to go the vortec route. the intake and carb I chose to use will actually be for my 383 with aluminum heads and whats why I want to use them. I do not want to have to buy twice, thats also why I am staying away from vortec heads.
Old Sep 28, 2005 | 06:50 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
just get that motor running with some budget heads used vortec or cammel backs or 441 castings, heck I would just use thos tpi heads i hear they flow decent. Use a performer intake or a torker 2, and a cam like specifed before graduly bring in a 150 shot Do not put the victor jr on it will not be in the power band for the motor, mismatched parts cause more harm than good. or better yet do not do anything with this motor sell the parts to put toward your 383.
later and
GB
rick
Old Sep 28, 2005 | 06:53 PM
Dialed_In's Avatar
The torker II is a horrible performance intake. Ok for stock carb/heads on a smog motor. Go with something like a Performer RPM or the Air Gap, you'll be happier.
Old Sep 28, 2005 | 07:53 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
See Sig
At the time of the dyno I had 11.9 A/F ratio and was only getting 30* timing advance. Also just swapped on a Team G intake. I'm hoping to bump that up a bit.
Old Sep 28, 2005 | 08:47 PM
89formulaws6350's Avatar
Car: 87 firebird,89 formula,74 Olds that runs 12.34
Engine: LG4,L98,455Olds
Transmission: 7004r,7004r,th350
If you dont want your TPI i will buy it.
Old Sep 28, 2005 | 09:10 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Actually I bought an L98 long block. The tpi was long gone. Sorry.
Old Sep 29, 2005 | 01:04 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
I figured you guys were gonna give me more crap about running a 750 race carb than the vic jr
L98 heads are really not that bad of a design, especially if you clean them up.
I was even debating on the double hump heads (sum-152123) that summit sells. It's either them or summit. This combo is only going to be on the car until early summer when the new heads and shortblock go in.
I basically want to use the valvetrain and induction system on the new motor when it is done. I know it is gonna be a mismatch for the heads (what ever heads that m,ay be at the time) but thats my current train of thaught.
I have had a fair share of nitrous cars before so I am not gonna hesitate on the 150 shot. Thats a baby shot Once the new shortblock is in I want to spray 250+
is there a really tight budget head that the vic jr can match up with?
ok, after some searching I found another good set of heads rather cheap. BRO-1021001 (summit PN) and they are 200CC brodix heads for 1k assembled. No question about them and the vic jr.
Keep shooting out recomendations guys. It's all taken into consideration.
Old Sep 29, 2005 | 09:46 AM
Dialed_In's Avatar
It's like beating a dead horse, everyone on this forum thinks a 750 is the smallest you can go, even on a 350
Old Sep 29, 2005 | 09:55 AM
Dialed_In's Avatar
What do you plan on dropping in it later? Those Brodix heads you listed are pretty much bottom of the barrel that Brodix offers. Only available in straight plug, cheap seats, valve springs they send aren't as good as they should be, heavy valves, poor valve job, not to mention the runner design is sub-par. lots of little differences between them and the Race Rites that aren't much more expensive and well worth it. If you plan on putting them on something that's going to utilize the potential of a Victo Jr., then these heads WILL hold you back. For a 300hp. motor, yes they'll be fine. But it you plan on building a performance motor that'll make 1.5-2 hp/ci then go with a better head.
Old Sep 29, 2005 | 11:21 AM
XJOSHX's Avatar
Car: 1988 Iroc-Z
well total plan in the end is;
direct port fogger WITH a plate system
fully forged high end 383
afr 227's race ported or custom ported dart PRO 1's
shaft mount roller rockers (when I do this i'll most likely go solid roller)
belt driven timing chain
2 speed powerglide
splayed 4 bolt main caps
Thats on the list of mods for next years spring. This years spring goals are jsut what I have been alking about this whole thread. Once the mew motor is in I am going to be worried the vic jr. is not gonna be enough and I am going to need a super vic
Old Sep 29, 2005 | 01:56 PM
jimmy_mac's Avatar
gonna need at a minumum the lt4 hot cam or the 270 HR comp cam(218 @.050, 224 @.050). Of course good springs. Get the heads at least flowing in the 220 + range on the intake with porting, and of course the exhausts up also. Might as well port the heads though if you're gonna upgrade later instead of wasting a lot of money now on new heads you won't keep.
Or compromise and get the AFR 210s now and use for both. AFR does make 210s right?
Old Sep 29, 2005 | 04:05 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
yeah AFR makes 210's, if not dart does. One company makes 210's and one makes 215's and I always get them mixed up. I'll probably be going bigger than that with the cam specs. I already have an AFR hydra rev kit laying around. I am not one to care about something being streetable. If it doesn't over heat or break it's streetable to me.
I would jsut buy the good heads now, but I have to bail my shortblock out of the machine shop. I also don't want to throw crappy heads on that short block so I figure by late summer next year I can have the good heads and shortblock done.
Them summit double hump heads are looking better and better by the day! cheap and after I use them I can probably sell them for a good price.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
matthew911
Aug 12, 2015 09:38 AM
