open headers
Old Nov 6, 2001 | 06:29 AM
JunkHead84's Avatar
open headers
what damage can u do running with open headers, just temporarily, i've heard burnt valves ?
Old Nov 6, 2001 | 07:32 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Open headers will not burn valves.
Exessive lean air/fuel ratios and retarded ignition timing will.
On a car with a borderline fuel system
with full exhuast (starves to motor for fuel at hi rpm) that is then run uncapped, the increase in breathing would now cause exessive lean mixtures and will damage the motor (pistons, valves) The real culpret
is the fuel system (pump,lines,filter) Once this is corrected, the carb will often need new jets 2 to 4 sizes bigger to feed all that newfound airflow.
Old Nov 6, 2001 | 07:38 AM
JunkHead84's Avatar
so basically what ur saying is its bad.
Old Nov 6, 2001 | 08:15 AM
F-BIRD'88's Avatar
<font face="Verdana, Arial" size="2">Originally posted by JunkHead84:
so basically what ur saying is its bad.</font>
No,, Open exhaust is not bad.... Running a motor at full throttle with exessive lean fuel mixtures... is....
Old Nov 6, 2001 | 08:22 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll be fine with open headers, people at the track do it all the time.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 6, 2001 | 08:47 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
My understanding of the subject (and I could be wrong) was that you are at risk of warping the exhaust valves, not burning them. The reasoning here is that the valves get really hot when the engine is running (duh). Anyway, when you shut the car off, if you don't have enough exhaust then they will be allowed to cool too fast by the outside air and can warp. This is a real possibility if you were to run the car without any exhaust at all. Maybe you saw the post another guy had about a car he was considering buying, the previous owner ran it without the manifolds. With headers you ought to be ok, but I wouldn't drive it any farther than the exhaust shop.
91 Z28
Come see The Vicious...
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
toyotekk
Sep 6, 2015 02:21 PM
Accerrito22
Sep 5, 2015 09:34 PM
luvofjah
Sep 3, 2015 07:08 PM
