305 and 350 TPI have different starters!!
Old Nov 6, 2001 | 08:59 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I'm putting a 350 in my 91 TPI that had a 305. The 350 block I got (from an f-body)came with everything, including the starter. When I went to hook up the wires to the starter, my positive cable from the battery was too small to fit over the stud on the starter, so I had to drill it out. Not a big deal, but jeez, can't anything be simple?
Anyway, I went by the parts where I work and looked up the starters for myself. Sure enough, 305s and 350s had different starters. I guess it's not a big deal since I already have the 350 starter, but does anyone know what the difference is, besides the size of the stud? More torque or something?
91 Z28
Come see The Vicious...
Old Nov 6, 2001 | 09:10 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i believe the 305 got a 153 tooth flywheel while the 350 got a 168 tooth flywheel hence the larger flywheel and different starter. why you ask? i guess to put less load on the starter by making it work less.
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
[This message has been edited by mystikkal_69 (edited November 06, 2001).]
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
