Rear Main Seal replacement in a 2-piece block
Old Nov 5, 2001 | 08:30 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've begun my 700R4 to T5 swap, and I've got to replace the rear main seal. 10k miles on the motor and it leaks like a screen door. Does the engine have to come right out of the car or can I get away with lifting it up a few inches? I want a 1-piece rubber oil pan gasket (that fugger leaks too), but I've heard that it makes the oil pan sit a little lower. I've got a cast aluminum pan, and as it is the fins already hit my exhaust.
Anyway, what am I in for on this project?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 5, 2001 | 09:14 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
With the 700r4 out you shouldn't have too hard of a time replacing the rear main seal.
Someone did a tech article on the replacement of the oil pan gasket. I haven't read it, but I would think that with the tranny out it would simply be a matter of jacking up the rear of the block and sliding the pan in.
Good luck with the seal swaps man.
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 6, 2001 | 06:15 PM
Jim85IROC's Avatar
I read Phil Parsins' article, and the motor needs to be lifted up a few inches. If I'm going to go through that hassle, I might as well just pull the bastard out and do it on a stand. 10k miles on the motor and I've already got to pull it.
The IROC Homepage
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
