Hood clearance
Old Nov 6, 2001 | 08:11 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Hood clearance
Okay here's the problem. My dad and I are putting together an 86 camaro 2.8 MPFI for my sister. The hood on it was dented up bad, so we found a fiberglass hood from an older Z (like an 83 I think). The problem is, this hood was meant for a carbed car. At the front of the hood on the underside, there is like a bar which goes across, and it oes not clear the air intake, where the filters are. It comes down about 1/2" too far to clear it. Is there an easy way to fix this? Like makeing a different intake? We really don't want to cut the underside of the hood.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Nov 6, 2001 | 08:47 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Ward,
If I remember correctly the 2.8 is a mass air setup. As long as you retain the Mass Air Flow sensor and any other sensors in the intake tubing you can basically run any kind of intake setup you like. You might want to see if K&N makes a kit for the car. If I happen to run across anything I'll let you know.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
