motor ID#s and cheep thrill combo
Old Oct 1, 2005 | 03:17 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Any one have the numbers hp tq on this motor . motor#s 1006036 heads 1998993 . What is my best combo of parts listed with a cam that will work with my stock heads. I have all parts listed flow-tec hedders edelbrock 3 inch RPM exahust edelbrock performer intake or wieand 8004 . Edelbrock 1405 carb or holly 1850 . Ingnition MSD 8360 dizzy and 6AL box .373 rear cog and 5-speed . Any info this set up fire away .
Old Oct 1, 2005 | 11:52 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
This is a 350 crate motor from GM 1987 4-bolt 2 piece Hecho en Mexico . I do not realy care what the output is . Just figured someone would now off the top of thier head .
I only feel like putting 300$ (give or take) in this motor whats the best way to get the most feel out of it ? With the parts I have.
Old Oct 2, 2005 | 01:10 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
wth is up with your casting numbers
Block should be
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear seal, "Hecho en Mexico"
And heads
3998993....current..350.........Goodwrench crate motors,"Hecho en Mexico",75cc chambers
Like most stock pistons its probably got a -10cc dish so it would be a fairly low compression ratio with the 75cc heads, not the greatest if you want to make big numbers.
I would go with a Performer intake and the Holley carb. You should also considder a cam change as it could definately wake a motor up with the right cam.
Old Oct 2, 2005 | 08:58 AM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
I am missing a 6 sorry . What kind of cam would this motor like . The edelbrock performer seems a littel mild . Also do I want dule or single pattern cam . Non CC car , I was looking at the crane powermax 212/218 in.ex .432" .459" would this put to much strain on my valve train . Or do you have a better idea ? first time cam swap .
Old Oct 2, 2005 | 11:49 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
So far theirs 2 things of edelbrock i wouldnt recommend from personal experience. their carbs and cams. To say the least i am not impressed with them.
Are you still running OEM pushrods, rockers, springs?
Old Oct 2, 2005 | 02:21 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Yes I am and kind of want to keep them . Set of aluminum heads in the future about a year off . Just looking for a little fun for now . I have to agree about the eddy carb no experience with thier cams . What can I get away with , or do I just tough it out for another year . The tranny and sus is not ready for big numbers right now .
IMissMy86TA
Aug 31, 2015 08:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
