Coolant leaking while cars sits....
Old Nov 6, 2001 | 07:58 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
I get small puddles of coolant residing in the drivers side of the base manifold "valleys". Kind of where the the head meets the intake. The puddles seem to appear more as the car sits. When I was driving it steadily this summer, the coolant was not appearing. I won't be driving my car any more since winter is coming. I think I had this same problem last year. I am quite sure it is NOT the thermostat housing doing the leaking.
I have had the plenum and runners off before, but not the base manifold. Is this just a gasket leaking? Or something more serious?
Anyone else seen this conditon?
Thanks for any tips.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Old Nov 6, 2001 | 08:04 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like an intake gasket.
When you have the intake manifold off, look real good at the manifold surface surounding the water ports. These are prone to corrosion and I have seen them so pitted the intake has to be repaired or replaced.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 7, 2001 | 06:59 PM
Car: 1988 IROC-Z
Thanks for the tip. The car has just under 60,000 miles, you wouldn't think it would be corroded yet. But my car has been sitting winters for the last 9 years, maybe that has something to do with it. Or maybe it's just a bad seal with the intake gasket from the beginning.
Now that I have a reason to pull that manifold, time for some more port work. Good winter project.
Anyone else?
Old Nov 7, 2001 | 07:21 PM
iroc5speed's Avatar
I got some too, it was the intake gasket. Eay fix, but it's a pain in the butt to change with all the wiring in the way
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
TheExaminer
Aug 26, 2015 04:59 PM
Exxon Limited
Aug 9, 2015 08:13 PM
