That air intake tube that goes to your throttle body...
Old Nov 7, 2001 | 11:21 PM
86BIRD-MY FIRST CAR's Avatar
Any way you can modify that tube or improve it so the air flows alot better?
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Nov 8, 2001 | 12:54 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Y not just take it off? replace the whole in-the-way cleaner assembly with an open element? That was the first thing I did with mine - what a difference! You can probably find and Edelbrock or K&N at your local parts store for under $50 (14x3"), including filter.
I guess you'd have to give up your investment in the old K&N filter, tho.
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
Exhaust is next!
Old Nov 8, 2001 | 11:05 AM
wait i dont understand, do you mean attatch the air filter directly to the throttle body?
86 firebird 2.8
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Nov 8, 2001 | 01:00 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
His car is multi point injection and his air ducting is like that of a TPI set up.So a 14x3 element will not work,only on a carb set up.The only mod I can suggest is to get a cone filter from K&N and attach it to the ducting with a small piece of pcv pipe(remove stock air box assembly).I did this on my 86 TPI T/A with no troubles.You might be able to use 88 and up GTA ducting which is much more straight shot to motor,also done on my T/A.I paid about $40 through GM for the GTA ducting,and around $30 for the filter,also looked alot better than the 86 air ducting.
1982 Z28:355,4 Speed,Lots of bolt ons
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Street Lethal
Aug 12, 2015 11:33 AM
Jake_92RS
Aug 11, 2015 10:39 AM
