what is the best cam?
Old Nov 6, 2001 | 08:05 PM
britered86transam's Avatar
alrihgt i have an 86 WS6 trans am. Its TPI with a 700r4 tranny and 3.27 gears. i want to put in a new cam. my question is what would be the best cam to get that would make my car loud and increase the horsepower? and are the lifter hydrolic? thanks
Old Nov 6, 2001 | 08:54 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
well, on paper the zz9 looks pretty good. but not on the web (at least not in this example https://www.thirdgen.org/messgboard/...ML/015149.html
You should at least have aftermarket exhaust (headers too)
[This message has been edited by jcb999 (edited November 06, 2001).]
Old Nov 7, 2001 | 07:00 AM
ok will a cam for a small block shevy fit in my 86 trans am?
Old Nov 7, 2001 | 08:36 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
yep. Since about 1980 all GMs (buicks-olds-pontiacs) came with chevy motors.
Old Nov 7, 2001 | 02:56 PM
SoCo80p's Avatar
thats not really true, BOP allways wanted to keep itself a little away from chevy, the big cars usally allways had the 307 olds, along with the 442's had the HO 307 and the GN's with the buick 6, the only pontiac the mass used the chevy engine was the firebird as the 305 was at the time GM's "performance" engine.
Old Nov 7, 2001 | 03:17 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
thats not really true, BOP allways wanted to keep itself a little away from chevy, the big cars usally allways had the 307 olds, along with the 442's had the HO 307 and the GN's with the buick 6, the only pontiac the mass used the chevy engine was the firebird as the 305 was at the time GM's "performance" engine.</font>
Well if anything, it was more like there were special models that got the non-chevy motors. Most of your V8 grandprixs and cutlass in the 78-82 range were chevy v8s.
But look at the turbo ta (the lame one not the V6 one). It used a pontiac V8 when everybody else was putting 350s in their non-chevy bodies.
Old Nov 7, 2001 | 08:16 PM
so then my 86 305 trans am is the same as a chevy 305? and will fit a cam for a chevy 305?
Old Nov 7, 2001 | 08:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
If it has 4 bolts holding on the valve cover the answer is yes.
Old Nov 7, 2001 | 08:55 PM
Adv. Duration: 278º
Gross Lift: .467''
RPM Range: 2400-5400 crane cams energizer
fair idle
Adv. Duration: 274º
Gross Lift: .450''
RPM Range: 2200-5200 crane cams energizer
rough idle
Cam Kit
Grind: 268
Lift: .477''/.480''
RPM Range: 1600-5800 compcams xtreme energy
Cam Kit
Grind: 262
Lift: .462''/.469''
RPM Range: 1300-5600 compcams xtreme energy
Cam Kit
Grind: 268H
Lift: .485''
RPM Range: 1500-5500 compcams high energy
Grind: 275/277
Lift: .462''/.482''
RPM Range: 2000-6000 compcams dual energy
Grind: 255/261
Lift: .429''/.438''
RPM Range: 1200-5500 compcams dual energy
Old Nov 7, 2001 | 08:56 PM
haha i forgot to type the rest...now out of those which would be best? and i am looking for aggresiveness so whut kind of idle?
Old Nov 8, 2001 | 01:52 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I would say either one of the 268 grinds would work well.... and I think that a few guys around here run 268H or HR cams... That 'dual energy' cam with the 275/277 462/482 lift looks kinda interesting as well... That one would probably work really well with a ported TPI setup.....
Well, I'm no cam expert, but that is my $.02 for the ones you listed.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 8, 2001 | 01:59 AM
Matt87GTA's Avatar
Also, to answer the question about the lifters, yes, they are non-roller hydraulic in your T/A from the factory.... But you will need to get new lifters to go with the new cam (you should be able to purchase the cam and lifters as a kit to save a few bucks...)
And if you go with one of the cams I commented on (the larger ones of the ones you listed), I would suggest a nice exhaust system (headers and cat-back), and maybe a small stall converter (2000 to 2500 rpm area) to go with a ported TPI setup. Your rear axle ratio is plenty good to work with with any of those cams you listed, IMO. With one of those cams, and the right stuff to go with it, you should have that thing really movin!!
Good Luck!
1987 GTA L98 MD8
My GTA
Old Nov 8, 2001 | 02:05 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
<font face="Verdana, Arial" size="2">Originally posted by britered86transam:
Cam Kit
Grind: 268
Lift: .477''/.480''
Cam Kit
</font>
Your all around best bet.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
