Just got into accident, please help
Old Nov 8, 2001 | 07:30 AM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
The car run over a 1' curb and looks like its totalled. Not much body damage at all, but the front end looks severely damaged. the wheel on the right side is tilted to the right. The car will not crank when i try to start it now, i'm thinking its the fuel cut off switch or other safety device. Does anyone know if our cars come equipped with anything like that in case of an accident? and how to go around it? thanks a lot
p.s. I am now looking to buy a 3rd gen with a 350 and a manual transmission for $4,000 or below, so if anyone knows a good deal please let me know, (i'm also looking in the classifieds) thanks a lot.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Centerforce dual friction clutch, 5spd,
0-60mph-7.0s-Gteched
Old Nov 8, 2001 | 07:44 AM
Car: 88 IROC
Transmission: auto
Can someone also tell me how to post on the classifieds? thanks
Old Nov 8, 2001 | 07:59 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The wheel problem is most likely a bent lower control arm. But I was unaware of 3rd gens have a fuel cut off like that. Not saying there isn't one just didn't think they did. Did you flatten the fuel lines, exhaust or oil pan? If you can get it to run it will bring more money.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***getting ready for new engine. TBI version of this http://www.airflowresearch.com/Articles/A3-P1.htm
Old Nov 8, 2001 | 12:15 PM
F0xBody50's Avatar
Let me say.... OUCH!
With a destroyed front-end, and obvious alignment damage, I think you're lookin at good money at a body shop to get it repaired...
It's probably a good idea to find yourself a new Camaro, and part out your old one, because you have some good equipment there in your sig...
-ONE2FLY
1990 IROC-Z Camaro
Artic White w/ Gold Decals, 305cid V8 TPI, 700R4 Auto w/ OD, 16" 1992 Z-28 rims (w/ white trim), Z-rated Extremos 245/50/16s (new), Power Options, T-Tops, Tinted Windows, Flowmaster Exhuast w/ High-Flow Cat-Back....
Old Nov 8, 2001 | 12:21 PM
Car: 88 IROC
Transmission: auto
Ok, i looked at it more closely today. The suspension seems to be pretty severly damaged, the a-arm is almost touching my headers, the steering gear box has a leak in it, the transmission is out of place, and the motor just won't turn over. I am definitely keeping all the parts that i've put into this car and will use them on my next one. The motor was approaching 140k anyways, so i guess i'm not loosing too much because the only thing that makes my car worth anything is all the parts and work that i've put into it. Thanks for your help and wish me luck in finding a new one.
Old Nov 8, 2001 | 12:33 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Sorry about the mishap...sounds like you twisted the frame and drivetrain pretty bad. Best, if not only bet is to part it out for $$$
BTW if you want to sell your dashboard pad and its in good shape, send me an email.
Thirdgens never came with 350's and T-5's...just auto.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: TBI & Suspension mods
Old Nov 8, 2001 | 03:27 PM
bhaas's Avatar
Wanna sell the T5? E-mail me if you do.
bhaas@bigfoot.com Thanks.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Veaceonee
Sep 29, 2016 08:15 PM
skip91
Sep 24, 2015 03:29 PM
LiquidBlue
Sep 13, 2015 02:24 PM
mult68
Aug 13, 2001 03:47 PM
