Cold starting
Old Nov 8, 2001 | 09:06 AM
Z28DJP1987's Avatar
Cold starting
Anyone with a high lift cam have a problem
with their idle after cold starting, giving it the gas to keep the Rev's up for about two or three minutes. And after this everything is normal?? This happens only in cooler weather.
Old Nov 8, 2001 | 07:39 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If you have a tpi engine, I would try testing the cold start valve on the passenger side of the engine. It would be located under a single tube inbetween the runners on the passenger side of the engine. It will have a connector that looks like an injector connector. Not for sure how to test it, problably with an volt/ohm meter. Dont know what the specs are
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
