Just flashed codes, now could someone tell me what it all means?
Old Nov 9, 2001 | 10:10 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
If it matters at all, the car is an 85 LB9 IROC. I did everything just like it says in the tech article on this page and this is what happened:
Tried jumping circuit 6 to 12 and got nothing. Jump circuit 5 to 6 and SES light flashed the "12" thing once. (didn't do it three times in a row)
After the first twelve it flashed 3 times then paused....
Then it flashed 4 times and paused...
Then it flashed 3 times again and paused....
Then it flashed 3 times and paused....
Then it repeated the "12" code again, then it went into the 3/4 flash sequence above again.
I have not even the slightest clue as to what all this means, so could someone help me out?
Eric
My 1986 Z2814.59@95.6
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles! no times yet, just got it to start.
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Moderator at: www.generation-3.com
Old Nov 9, 2001 | 11:00 AM
ede's Avatar
ede
you have a trouble code 34. i don't have my manual in front of me but find code 34 in your manual for your engine and follow the trouble shooting flow down
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 9, 2001 | 11:15 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
ohhh, well i guess that would make sense then. I just looked it up and it says :
34. low voltage (high vaccuum) at mass air flow sensor (or MAP sensor)
Thanks for the help,
Eric
[This message has been edited by zupmanZ28 (edited November 09, 2001).]
Old Nov 9, 2001 | 11:22 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i just looked through my 85 Chevy Camaro Service manual and found absolutely nothing on the codes. Unforntunately i dont have the original manual for the car, so could anyone provide me with the troubleshooting steps?
Eric
Old Nov 10, 2001 | 09:43 PM
DaveV85iroc305TPI's Avatar
Code 34 is set because ECM sees low voltage at CKT 998. If you disconnect the mass air flow and the code 34 repeats then the wiring or ECM is at fault. If the burn off cycle has not been functioning the MASS Air flow sensor output may become low enough to set code 34.
Low air flow means low voltage. check for instake leaks around the throttle body or dirty air filters or blockage to the air intake.
My 85 Iroc
Old Nov 11, 2001 | 01:20 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Go here.
https://www.thirdgen.org/newdesign/f...gen.shtml#misc
It'll tell you what all the codes mean. To help you diagnois the problem, get a Haynes or Chiltons repair manual, or both. I've heard they both tell you stuff that the other doesn't.
AJ
junior419
Apr 7, 2025 11:35 AM
BumpaD82
Feb 26, 2016 02:57 PM
lethaldomestics
Sep 21, 2015 01:18 PM
Reese-J
Sep 14, 2015 02:43 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
