tranny swap, engine swap, etc etc......
Old Nov 9, 2001 | 06:45 PM
camaro6spd's Avatar
Ok seeing that it would fall under 2 catagories, I choose to put it here. Now as some of you know my car had a fatal encounter with a deer. Now I want to take the perfect drivetrain and engine out of it and put in a 91-92 camaro. Now how hard would it be to install it in 305 TBI auto car. I would need to swap FI and to a 5 speed. how hard would this be seeing i have all the parts I need (my old car )
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways.
AIM: IROC 5spd
http://www.geocities.com/chevy5spdiroc/87Roc.htm
Old Nov 10, 2001 | 01:47 AM
Jza's Avatar
Jza
Since you have the whole car right there, it should be pretty straightforward. The problem most people have when they try a swap is not having a certain part or having to fabricate it (like the hard fuel lines).
Don't forget to swap the fuel pump.
Old Nov 10, 2001 | 10:22 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You wrecked the car in your sig. I would have cried.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 10, 2001 | 01:14 PM
camaro6spd's Avatar
yeah it sucks i know.....my father and I put in the new engine this summer so the removal and installation of the engine should not be a problem. What kind of time do you think it will take to swap over from TBI it TPI and i decided to forget about the auto manual thing. OR my other option for this car is posted in the suspen/chassis/brakes board...well two of them. Just take a look see and tell me what you think right there.
Old Nov 11, 2001 | 08:52 AM
camaro6spd's Avatar
I found that it would be cheaper do to a V6 to V8 swap....see motor swap board for futher info and questions.
1987 Black 305 TPI 5spd IROC, G92, 9-bolt 3.45, Lowered, Cat-back, Air Foil, Sub Frames, Huge sways........Wrecked by a deer.
Looking for a 1995 Honda CR125R in NJ or PA. I have one for sale...RRP Sleeve Job, Vertex Piston, New Sprokets and a x-ring chain, new botom end with crank...etc etc
look here
http://www.classifieds2000.com/cgi-cls/ad.exe?P1+C18+R100004616
AIM: IROC 5spd
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
