Want to build a 350 soon any help welcome
Old Nov 10, 2001 | 11:05 PM
Illegal T/A's Avatar
Whats up guys I have been wanting to build a 350 for quite awhile now. I was wondering if it was possible to build a 300+ hp engine with out messing with stock the bottom end,and Could I use the stock pistons?. I was thinking of doing head work, getting cam and lifter set,new springs,valves,rockers,
push rods,and a performance intake. Also
What did u guys do on your 350 buildups(not tryin to be a copy cat or nothin haha ),I would like to know everything I can, What cam did u use,intake,what did u have done to your heads. I am in college, and dont have alot of dough to work with.what do u guys think i should do?
Thanx to all and *** bless
I Love Smokin Tires
Keep Tryin Never Give Up
Your Day Will Come
Old Nov 11, 2001 | 12:20 AM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
Well just with what you said you should be able to hit 300-350 fairly easily. Go with a medium sized cam. Too much would be bad and too little won't do a whole lot for you. The key to a good motor is matching all the parts. You want to figure out what RPM range your motor will spend most of it's time and improve power in that area. Upon doing this, you usually end up improving power over the whold RPM range and having more than enough where you will commonly need it. But like a said with a decent cam, I would say 270-280 advertised duration a little head work, good exhaust and a good intake setup you should be able to easily turn your tires into a puddle of molten goo, and fill the air with smokey clouds ofsacrificial rubber. Not to mention any ***** or rustang that comes along. Hope this helps, I would go into more detail, but it's all a matter of your pocketbook, emission laws where you live and how much streetability you want.
Jason
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns w/baffles removed, Throttle body airfoil.
"The reason most import drivers only focus on looking fast is so they can sit there staring at their car and dream about it being fast, because there's no way for them to match American muscle."
Old Nov 11, 2001 | 02:12 AM
Emissions is not really a concern but,yes i want it streetable,even though I have a second car.
I Love Smokin Tires
Your Day Will Come
Old Nov 11, 2001 | 08:14 AM
E-Z Rollin's Avatar
Heads and cam are the keys to hp. If you're limited to stock type make sure you get a set with good flow numbers,these with Comp.268 or cranes 272 cam a 2 plane edelbrock rpm or weiand 8004, Q-Jet or 600 Holley and compression ratio 9 to 91/2:1 will get you 300/350 hp and a very streetable perf. engine.If you want more specific info. [head #]myself or others can supply them.
Old Nov 11, 2001 | 09:46 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Is money an issue. I can't give you too much info on heads or a cam. But as far as exhaust SLP makes the best headers, and I would go with a Hooker cat-back. What kind of tranny will you be using. A stock 700r4 probably won't handle that power for long and a T5 definately won't. Rebuild the tranny with a Transgo Reprogramming kit, and get a TC with a matched stall speed of your power band. You say you have another car, yet you still want this one to be streetable, then I would go with some 3:73 gears. Of course you just mentioned an engine rebuild, but you don't necessarily have to do all engine mods to have a fast car.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 11, 2001 | 04:13 PM
Money is always a issue with me LOL,but I am willing to do what it takes.So I wouldn't have to necessarily do anything to the stock bottom end or change pistons?.After how many miles a engine has on it does boring come in to play.
I Love Smokin Tires
Your Day Will Come
[This message has been edited by Illegal T/A (edited November 11, 2001).]
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
