How Much Are Injectors?????
Old Nov 10, 2001 | 07:42 AM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
Hey guys, how much are the injectors (Each) on a 89 GTA 5.7?
Or about how much would it cost to replace them all?? And is it a hard job??? Just curious
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs; Removed Smog Pump and all other Smog related parts.
Old Nov 10, 2001 | 08:49 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Injectors from GM are about 80 bucks each, IIRC.
Accels and SVO's run about 225 a set of 8.
Others are out there too...MSD and a few others, check the mail order shops for pricing.
Also, check with Rich at Cruzinperformance.com, he carries the Accels for sure, not sure what others he may have, beside OEM for flow matching.
Old Nov 10, 2001 | 10:44 PM
Engine: ZZ4 - 350
Sounds good man. Thanks for the info. I am going to check it out.
Take care
Mike
Old Nov 11, 2001 | 04:38 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I was in the market for injectors last winter. For a 5.7 TPI GM wanted $137 a piece for 22lbs. I was going to go with Accel or SVO's but they only made 24's and in that case the car would run rich and cause more problems. I ended up going with 22lbs injectors from MSD They were 55 a piece. At first i sent my injectors to rich at cruzin and he said they were not worth cleaning and that they were all bad.
Old Nov 11, 2001 | 04:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock Multec injectors are crap, the worst in the business for spray pattern, reliability, and everything else... I would not recommend bothering with cleaning, repairing, or least of all, buying new ones.
You might want to check out the PROM burning board and learn how to make your own chips, and then get a set of decent quality (not Rochester Multec) 24# ones after you find out how to make the necessary adjustments to the tables.
ICON Motorsports
Old Nov 11, 2001 | 05:08 PM
Engine: ZZ4 - 350
Thanks guys for the input. I am looking into a few options in the near future. My car runs great, but it does have 102000 miles on it with the original injectors. I would like to change the injectors. I know the car certainly won't run any worse. I am trying to do a lot of small mods, that are not major such as a camshaft, heads, etc.
thanks again!
Mike
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
