Service light
Old Nov 10, 2001 | 06:00 PM
Trent257's Avatar
Service light
it goes on after like 10 minutes of driveing, how do i find out what this means, do i need any equipment to do so, or is there an easy way
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 10, 2001 | 06:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe it is directly related to you EGR.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 10, 2001 | 06:34 PM
91TA's Avatar
You can go to Sears and buy a code scanner for about $30.00. I also have heard you can you a paper clip but I don't remember which pins to touch.
Old Nov 10, 2001 | 08:00 PM
CloudZRoc's Avatar
use a paper clip or piece or insulated wire and under the driver dash there should be a terminal try the upper most left pin and the upper most right pin then it'll ring em off.. it will ding....(Pause) ding ding . then go into the codes as every time the light comes on it counts for a one example Code 34 MAF sensor malfunction 1+1+1 pause 1+1+1+1 , then back to ding.... pause ding ding
87 IROC-Z Bright Red, New 305 TPI, Soo to get new body work and paint job, Also 1st to get new Tranny. Virtually Stock, except to get new SLP Runners and Headers...
Old Nov 11, 2001 | 02:37 PM
Trent257's Avatar
ok that didnt work, any other places, or will i need the 30$ thing
Trent
---Car---
---Stero---
profile cl640 110x4
Old Nov 11, 2001 | 04:22 PM
Jza's Avatar
Jza
It didn't work because he told you the wrong pins. It's the upper-right most pin, and the pin immediately to the left of it. The upper-left most is the TCC lockup pin. All you did is signal the TCC solonoid to activate.
Old Nov 11, 2001 | 04:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That'a probably the coolant temp sensor... the ECM expects the engine to reach some reasonable temp within some reasonable time of running, and if it doesn't, it sets a code. 10 minutes is about how long it waits.
Pull the codes and see what it says, there's a list of them in the tech section of this site.
ICON Motorsports
Old Nov 11, 2001 | 05:01 PM
Vader's Avatar
Trent,
A guy from Waukesha should really have this file:
GM Error Codes.pdf
It has everything you'll need except the paper clip.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 11, 2001 | 05:22 PM
Trent257's Avatar
hehe, ok i got code 12 and 32, 12 i know is normal, then 32, my haynes says its with the egr or vaccumes, i broke a vaccum that went to the intake from something, to i tapped it back together, could this be it? how else can i fix it
Trent
---Car---
---Stero---
profile cl640 110x4
[This message has been edited by Trent257 (edited November 11, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
