Kinda silly question
Old Nov 11, 2001 | 10:57 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
...regarding the distributor.
Is there only one correct position for it? I mean, as long as it goes down all the way, you can always just make whichever position on the cap be #1 (assuming the engine is at TDC) - or is that wrong?
If there is only one correct position, what is it with the engine in TDC?
Just wanting to double check before going on.
Thanks,
Ken
1986 IROC-Z Conv't
- White Gauges, 17x9.5 TT II rims w/275/40x17" F1s, 1.5" Jamex Lowering Springs, BMR stb, Lakewood APR, PST suspension parts, Edelbrock Trailing Arms, KYBs, Edelbrock RPM Cat-Back, Edelbrock JHC Headers, Catco, World Products Heads, CompCam, SLP runners, Ported Plenum, K&N, Airfoil +polished/billet dress-up stuff
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Nov 11, 2001 | 11:02 PM
LottaBallsCamaro's Avatar
Yeah but I wouldnt reccomend it, just put it in the right way and be done with it.
EDIT: now that I think about it, I'm not sure...
[This message has been edited by LottaBallsCamaro (edited November 11, 2001).]
Old Nov 11, 2001 | 11:21 PM
AlexJH's Avatar
Engine: 5.7L V8
Well, the rotor is pointing at whichever cylinder should be firing at that time.
So if cylinder #1 is at TDC, it should be pointing to that terminal.
Remember that this is for the compression stroke. The piston comes to the top for the exhaust stroke as well.
Clear as mud?
Old Nov 11, 2001 | 11:35 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ChevyKen:
</font>
Yup. I've had to intentionally install them way out of the "normal" position to clear larger vacuum advance/retard assemblies behind aftermarket manifolds. The ECM and coil don't care where it is pointing, as long as you can time it correctly.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 11, 2001 | 11:39 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Yeah, I know that part - I guess my question wasn't clear. What I mean is, is the when you slip in the distributor after having it out, it will slip in in more than one position, which again will lead to the rotor pointing in different directions depending on how it is turned before slipping it in.
My question is, when the distributor is in place, and the engine in TDC (firing), should the rotor be in one position, say straight forward for example, and no other direction? Or, does it not matter, you can just slap the plug cable for #1 on the terminal to which it is pointing, no matter where it is?
Hope that was somewhat easier to understand..
Thanks,
Ken
Old Nov 11, 2001 | 11:40 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Ahhh, Vader got it straightened out before I was done replying.
That was the answer I was hunting for!!
Thanks a lot man!
Ken
z28addict8490
Sep 5, 2015 03:56 PM
FreeSpirit
Aug 29, 2015 05:47 PM
redmaroz
Aug 16, 2015 11:40 PM
