figuring your horsepower?
Old Nov 8, 2001 | 10:02 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I know there is an equation somewhere to find out how much horsepower you have from your 1/4 mile time. The only problem is, I can't find it. I checked the equations page, no luck. I thought I'd post and see if one of you guys could help me out. Thanx
Old Nov 9, 2001 | 03:17 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
MPH = 234.74 x (cubic root of power/weight)
HP = (MPHx.00426)x(MPH x.00426)x(MPH x.00426)
This is for rear wheel HP or net hp when the weight and MPH@ the end of 1/4 mile is known.
There is no real reliable formula for finding the hp from the 1/4 mi. ET because
traction can vary, a bad launch or improper shift point will throw off the ET. But MPH will be effected very little.
Flywheel HP is generaly 15 to 20% greater than rearwheel HP. but can vary.
At least it makes for some interesting bench racing....
Old Nov 9, 2001 | 05:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You forgot the weight term:
HP = (0.00426 x mph)<SUP>3</SUP> x weight
Old Nov 9, 2001 | 06:35 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
If your mathmatically challanged, you can use the web
http://home.tampabay.rr.com/yz250/calc.htm
Old Nov 9, 2001 | 07:10 AM
jag's Avatar
jag
Try this one http://www.smokemup.com/utilities/calc.cfm
Old Nov 9, 2001 | 08:23 AM
F-BIRD'88's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
</font>
Old Nov 12, 2001 | 01:15 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Thanx for the help, I knew there was a formula but didn't remember what it was. I'm heading to the track on wednesday. If I can get my tires to bite hopefully I'll have a fairly accurate HP reading. Thanx again.
Old Nov 12, 2001 | 01:30 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
FormulasOnly
Jul 23, 2018 08:47 AM
92projectcamaro
Dec 8, 2015 12:25 AM
GageBrand
Oct 22, 2015 02:30 PM
Nikole
Sep 24, 2015 08:12 PM
