Spark plug reading
Old Nov 11, 2001 | 11:35 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Spark plug reading
Since I cant find my spark plug guide I'd figured I ask here.
I changed the plugs in my RS yesterday and 7 of the plugs were all black except the insulator, which was half brown half white and some had deposits on them. The #8 plug was oil soaked.
Also too now the car is running rough.. Great time to make sure all the wires are attached securly and to ohm them out..
If it isnt one thing it is another..
Oh it is a 90 RS 305 TBI A4 timing set to 6* with 185k
Kat
[This message has been edited by Kat (edited November 11, 2001).]
Old Nov 11, 2001 | 01:15 PM
DM91RS's Avatar
Car: 91 RS
When my oldest daughter had a TBI Trans Am hers done the same way on #8 and what I found out was the intake gasket was leaking. I replaced it and all was well.
Old Nov 11, 2001 | 01:39 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Thanks DM.. I already replaced the intake gasket earlier in the year.
I know that the valve guides/seals are shot.
Kat
Old Nov 11, 2001 | 02:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Black soot on the threaded metal part of the plug with a "colored" porcelin is ok.
when the deposits get too bad or the gap opens up, its time to replace 'em.
Black or silver peppered porcelins or damages porcelins is bad.
Old Nov 11, 2001 | 04:54 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Kat:
...If it isnt one thing it is another... </font>
...and if it isn't another, it's one thing.
Make sure the plug heat range is correct, and the gap is stock. If you already know you have loose valve guides, you should already know why the #8 is oil soaked. You might be able to "cheat" and install a hotter plug in that cylinder.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 12, 2001 | 08:52 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Vader they are the ACDlecos RTS45's gapped .035 .
I'll try the hotter plug idea!! Thanks!
Kat
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
