Which wheels on S-10
Old Nov 9, 2001 | 04:40 PM
CODY BEHNKE's Avatar
What camaro wheels are on S-10's? The front offset ones or the rear offset ones?
I know it's only one set but which one?
Old Nov 9, 2001 | 06:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're 15" wheels IIRC, which are all the same offset. Only the 16s and larger have the different offsets.
ICON Motorsports
Old Nov 11, 2001 | 09:49 AM
Yeah, what wheels do the 96+ use? The ones with the 91+ RS/Z28 wheels, all front or all rear. They use only one set rear or front?
Old Nov 11, 2001 | 10:29 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I've seen the aluminum ones 15x7 4-3/4 lug pattern, on many different vehicles..
Or these ones
Okanagan Thirdgen Association
_ _____________________ _
89 RS Camaro, LO3 305 TBI
Autometer Air/Fuel Ratio Guage
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
[This message has been edited by FastElectrics (edited November 11, 2001).]
Old Nov 11, 2001 | 03:54 PM
E-Z Rollin's Avatar
As you said the 16x8 camaro wheels have a different backspacing front to rear.When the factory used 3rd gen camaro wheels on the S-10 [ ZQ8]they used 4 front wheels,but you can use the dedicated wheels as long as you keep them front to rear, the rears won't clear on the front.I bought mine from Pace Chevrolet,the have a website.OR,if you could just get four front wheels they will clear front or rear.
Old Nov 11, 2001 | 04:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
IIRC, the ones they used on the S-10s are a +4mm offset, which is nothing.
That about the same as the 0mm offset on the fronts of our cars. 4mm is the same as 5/32". I think it'll be OK.
AJ
Old Nov 12, 2001 | 04:43 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Wait, The 15x7" wheels that come from earlier Z28's and later RS's, (like the first picture) have different offsets front to rear? Why don't they say front or rear like the 16" IROCs do?
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Nov 12, 2001 | 08:09 PM
AJ_92RS's Avatar
Now your confussing me.
The Iroc wheels never came on the S-10. Only the 16" ones that were used are the ones on 91-92 Z28s and optional on the RS.
These
Those are the only ones that I've seen GM put on S-10s that look like the Camaro's wheels that are 16".
The 15" wheels, like the first ones posted above, don't have diff. offsets. They're only 7" wide and that wasn't enough to cause any clearance problems with the body/suspension.
AJ
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
