Roller Cam Bearings
Old Oct 10, 2005 | 06:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Roller Cam Bearings
Real quick question: Do the 50mm roller cam bearings install the same way as the normal bearings? Same type of tool, technique, etc? Or is there some special roller bearing tool and procedure?
Edit: Oh, and has anyone ever used the Comp Cams composite distributor gear to know if they really do wear better than the bronze gears?
Old Oct 10, 2005 | 08:49 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
The roller cam bearings use a special installer although you may be able to use a regular installer. I have no idea about the composite distributor gear though.
http://www.compcams.com/Technical/Cu...g/HTML/368.asp
Old Oct 10, 2005 | 09:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
I didn't even think to look at Comp for the head! Thanks!
Old Oct 11, 2005 | 05:05 AM
ede's Avatar
ede
not looked much into it, but doesn't roller cam bearings require the block to be bored oversize to accept them?
Old Oct 11, 2005 | 09:28 AM
Yes they are a different diameter from the stock cam bore. And unlike regular cam bushings, which are 3 different outer diameters in a SBC, those roller cam bearings are all 5 the same outer diameter. IIRC they also require a different cam journal diameter.
People with dry-sump oil systems (no oil pump driven by the dist) get good results from the plastic gear. People with wet sump oil systems (stock, where the dist drives the OP) not so good. It looks like they last about the same as bronze in a wet-sump system, maybe a little better. But I haven't heard from enough people to know for sure, and I haven't used one yet.
Old Oct 11, 2005 | 10:46 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Yes, and I plan on such over the winter months.
junkcltr
Aug 2, 2019 11:12 PM
anesthes
Mar 10, 2016 10:35 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 26, 2015 01:37 PM
