New locks and retainers needed?
Old Oct 10, 2005 | 09:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Installing new Comp 983-16's 1.25in spring to refresh a stock set of spring for a Cast set of L98 Heads and to handle the new cam. 463/470 Lift. Can I get away with the stock retainers and locks or should I reuse the retainers and new locks, vise versa, or all new.
Old Oct 11, 2005 | 06:37 AM
ede's Avatar
ede
i'd trash the factory retainer and rotators and buy a set of retainers from comp or lunati and most likly reuse the locks
Old Oct 11, 2005 | 02:59 PM
Damon's Avatar
Just remember if you do ditch the stock rotator/retainers and replace them with standard retainers you must shim the exhaust valve spring about 1/16" to make up for the difference in retainer thickness (affects the spring's installed height).
For a stock or nearly stock refresh I would keep reusing the stock parts myself. Yes, even the lousy rotator/retainers.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
