What's causing this in my brakes?
Old Nov 10, 2001 | 04:51 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I haven't driven my car anywhere yet, but I noticed today while I had it running in my drivewat that if I press the brake pedal it goes to the floor and I see bubbles inside the master reservoir. Does this mean my master is shot??
Old Nov 10, 2001 | 04:59 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Sounds like you have air in your brake system. You need to bleed them to sqeeze the air out.
Old Nov 10, 2001 | 05:05 PM
82camaro's Avatar
Car: 82 camaro SC
If you haven't had the brake system open recently, it may be something more serious. Air has to get in the system somewhere.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 10, 2001 | 09:48 PM
Car: 89 IROC-Z
Engine: 383
I had entirely everything out, but I thought I got all the air out when I bench bled the master and bled all of the lines.
Riccioli Performance Motorworks
--RPM Racing--
Yes!!! After a year and a half it's finally running!! 383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Now I just need $$$$ for paint, wheels, and tires.
Old Nov 13, 2001 | 09:51 AM
Car: 89 IROC-Z
Engine: 383
BTTT
--RPM Racing--
Frozer!!!
Jan 19, 2024 04:55 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
stalkier
Aug 21, 2015 01:54 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
