theres only 1 PCV right?
Old Nov 13, 2001 | 08:09 PM
breathment's Avatar
On my car, passenger side is the PCV while the drivers side is just a 90* connector (breather hose?) this is the way its supposed to be right?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 13, 2001 | 08:13 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
[QUOTE]Originally posted by breathment:
[B]On my car, passenger side is the PCV while the drivers side is just a 90* connector (breather hose?) this is the way its supposed to be right?
can't verify the '89. but, my '86 has the PCV on the driver's side and the 90* elbow to the TB on the passenger side.
Old Nov 13, 2001 | 11:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It doesn't matter which side they're on as long as the PCV and breather aren't on the same side. Air is supposed to be drawn in through the breather, down into the crankcase through the head, up into the other head, and out through the PCV valve.
Old Nov 13, 2001 | 11:40 PM
breathment's Avatar
ok, thats what i thought, but then i got confused.
thanks.
- David
Old Nov 13, 2001 | 11:56 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
the breather goes to the TB and the PVC valve goes to the intake manifold.
Pac J
May 17, 2020 10:44 AM
tyeo098
Nov 30, 2015 06:27 PM
NZKnight
Oct 15, 2015 02:47 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
