emissions system
Old Nov 14, 2001 | 12:17 AM
84Camaro305's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 TBI
emissions system
The tube that runs from the carb to the evap canister purge valve seems to have been cut, then a bolt was jammed into the ends of the cut tube. I have no clue why one of the previous owners did that...but I would like to know why, if possible, and what it would hurt being like that. Also, this is probably a stupid question, but would a clogged catalytic converter cause an exhaust leak? I think that I have a leak where the exhaust pipe is mounted to the engine. My engine seems to be running a rougher than usual, I've replaced the spark plugs, so that shouldn't be it...not quite sure what's up with it.
Old Nov 14, 2001 | 12:26 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
A clogged cat would make an ex leak sound worse, just due to more back pressure.
The evap hose is just a bowl vent for the carb, it doesnt hurt anything if it is off and plugged, usually people will do that when the hose breaks cause they think its a vac. leak.
Other times the canister is full of gas and it runs better with it unplugged.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
86White_T/A305
Sep 21, 2015 05:28 PM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
