Weight of 305 stock rods and pistons ?
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
How much do
1) The stock (5.7 correct ?) conencting rod weigh ?
2) The stock 305 piston (for the L03) weigh ?
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Sort of like asking " What's a Hen-way?
Some things you just have to measure for yourself.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Their was probably quite a variance in weight over the years so grab yourself a gram scale the next time you have the parts in hand.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Re: Weight of 305 stock rods and pistons ?
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Re: Re: Weight of 305 stock rods and pistons ?
Originally posted by firebirdjosh
Stock can either be 5.0 or 5.7 if you are talking about a V8 in our cars. You have a 5.0 if you have a 305.
Car: 86 T/A
Engine: HSR 355
Re: Re: Re: Weight of 305 stock rods and pistons ?
Originally posted by Zed'er
I believe he's talking about the rod length, not the liter size of the engine.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
He's talking about the length of the connecting rod. All factory SBCs have 5.7" rods, except 400s which are 5.565"
Car: 1991 Camaro RS
Engine: LO3
*shrugs* So I assumed people knew how much their internal engine parts weigh
And yes ... of course I was wondering about the 5.7 INCH connecting rods
Engine: 383 Carb
Transmission: 4L60
Well I know how much my rods weigh, but I don't know anything about the weight of anybody else's.
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Give your local GM dealer a call, they should have specs on the parts.
As for my rods weights, only ***(why is g0d sensored?) knows and they are probably all different weights
Engine: 383 Carb
Transmission: 4L60
Car: 1991 Camaro RS
Engine: LO3
I simply wanted to have it for some calculations .. i.e. .. how much weight one could save (if one would even save) by going to lighter rods .. maybe 6.0 length .. and light hyper(ah heck
I give up on spelling that one) pistons
I give up on spelling that one) pistons Joined: Mar 2000
Transmission: 4L80E/4L80E
I have an '86 LG4 shortblock and '87 LB9 shortblock sitting in the garage. The '86 has X rods, the '87 some lightweight thing. I haven't taken either apart, but if I had to guess, I'd guess they weigh about 20-30 grams different from each other.
Of course, to date I've had absolutely no incentive to take either apart to find out how much they weigh.
Oh, the pink rods in my ZZ3 shortblock weighed 604-608 grams with caps, bolts, & nuts prior to balancing.
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
