Fuel Injector Cleaner...waste of $$$?
Old Nov 13, 2001 | 09:56 PM
Iroc n roll's Avatar
What are your thoughts on fuel injector cleaner additives? Are they worth it or is it just a waste on money?
"Though I cruise through the valley of Rice I shall fear no turbo, for torque art with me."
--Cullan Hooley
1985 IROC-Z w/T-tops, 305 out and 350 L98 TPI engine in, Hooker Super Comp Headers, 3" Hooker Super Comp Cat-Back, Dropped Cat, Rebuilt TH700R4 with Shift kit, 2,800RPM Torque Converter, 3.73 Richmond gears, Auburn posi differential, Accell SuperCoil, Accell 8mm racing wires, BBK AFPR, Homemade Ram-Air (thanks to askulte), MAF screens removed, Dropped A/C, Dropped A.I.R, TB coolant bypass, Hurst Dual-Gate Shifter, SLP Air Foil, K&N filters, Holley performance fuel pump, Spohn Subframe Connectors, Re-located Spohn Lower Control arms, LT1 cam, 150 shot of nitrous, and more to come.
Old Nov 13, 2001 | 10:04 PM
89BlwnRs's Avatar
In my opinion, pretty much a waste of money. They may make a slight difference on a car that is in really bad shape are far as the fuel system is concerned, but for cars that are in any decent shape whatsoever, they are a waste.
Just my thoughts,
Jason
Old Nov 13, 2001 | 10:17 PM
breathment's Avatar
i just fill up with chevron (with techron)every tank. don't know if it does anything, but its finally the same price as the other stations around here. 1.21 prem.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 13, 2001 | 10:50 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Fuel injector cleaner is one of those things.. if its doing its job you'll never notice anything change... if not then you got problems. I would run some once in awhile wont hurt anything and it might just help. But dont expect any change in performance.
Old Nov 13, 2001 | 11:02 PM
age's Avatar
age
Car: 1992 Z28 1LE
I believe in them. After about 175,000kms on the motor, we had the heads pulled off and the top of the pistons were a tan color with some aluminum still showing here and there.
The way I see it is, a few dollars here and there can't hurt. Even IF they didn't work, it's just a few dollars. But consider the positive outcome if they did work, even just a little bit.
Old Nov 14, 2001 | 12:46 AM
cort351w's Avatar
I bought my car a couple months ago from a guy in Michigan who had been storing it in a barn. The car is in practically new condition (all mods in sig I have done). On the drive back to Texas, I put fuel injector cleaner in with each tank after the first fillup.
Result: 1st tank: 22 mpg
2nd tank (w/injector cleaner): 23 mpg
3rd tank on (injector cleaner for
3rd, 4th, and 5th tanks): 26 mpg
virtually all miles were highway miles. Was this just because I was driving a car that hadn't been driven more than a few miles in the last five years or did the injector cleaner help? I don't know, but those are the numbers (I wrote them down at each fillup so that I could compare).
Now I get about 18.5 mpg with mixed stop and go , regular city, and highway driving. I got 22mpg on one tank, but I have no idea why.
91 formula WS6 305 tpi, T-5, 20,xxx actual miles, Cyclone headers, true dual exhaust, Moroso Blue Max wires
[This message has been edited by cort351w (edited November 13, 2001).]
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
