Chevy 302/327?
Old Nov 14, 2001 | 09:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Chevy 302/327?
I will be replacing my engine soon, and I am not sure what engine i want to put in. I might jsut put in another 400, but I wouldnt mind having something that can rev, which a 400 will not do. What kind of rpms can a 302 or a 327 do? Also, would either of these motors be a good candidate for a turbo or a blower?
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
Old Nov 14, 2001 | 09:02 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Read this first
http://web.camaross.com/bb/Forum13/HTML/004647.html
Old Nov 14, 2001 | 09:42 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
7500 rpm? Sweet! Also, since I've already got the 400 block to rebuild, what about a 377? does anyone know what kind of rpm they will turn out? Also, Could I use stock internals or are they too weak? And is a 400 block bottom end strong enough for 6 or 7 thousand rpm or would i need something like a girdle for the main caps
1983 Firebird
TH700R4 Auto
Small Block 400
Old Nov 14, 2001 | 10:11 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Stud the mains. I would not recommend going with aftermarket caps/4bolt splayed caps unless you have to align bore and are planning NOS.
Don't use a stock cast crank. Get a cat (word of late is that CAT sucks), SCAT crank or at lest a steel 350 crank. You can find a new forging for less than 400bucks on ebay.
http://search.ebaymotors.com/search/...t&maxRecordsPe rPage=30&skip=30
Use a high quality rod. like http://cgi.ebay.com/ebaymotors/aw-cg...item=597702305
As in the camz28 tread, try to decide how fast you want to go, then gear the motor to be near that rpm at the end of the run (what ever run you plan), and from that you will know how much hp you will need and how high to turn it.
[This message has been edited by jcb999 (edited November 14, 2001).]
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
z28venezuela
Oct 24, 2015 08:15 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
