Fresh distributor
Old Oct 14, 2005 | 05:50 PM
Ant's Avatar
Ant
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
Fresh distributor
I have a quick question I am installing a new distributor in my friends 87 iroc. When I put the dampener at 0 TDC where am I suppose to have the metal part on the rotor pointing. I have the #1 cylinder at TDC right now.
Old Oct 14, 2005 | 08:06 PM
Ant's Avatar
Ant
Anybody???? I know someone has to know.
Old Oct 14, 2005 | 08:47 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
to #1 on the cap... So it could go in pretty much any way yo want.
But if i remember right, pointed between the drivers side fender and headlight. also if your running a vacume advance setup the vacume port should be pointed towars the passenger side tire.
Old Oct 14, 2005 | 08:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Yup what he said... Point it at cyl number 1
Old Oct 14, 2005 | 09:53 PM
Ant's Avatar
Ant
Alright got it guys thanx for the input.
Old Oct 14, 2005 | 10:56 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
There's 2 TDC's per combustion cycle remember....
TDC compression and TDC exhaust. Be sure it's on the compression stroke. Or, if the engine is already put together, you can look at the valves. If both are closed, it's on the compression. Or, if it doesn't fire up or backfire/sputters, try flipping the distributor 180°.
Old Oct 15, 2005 | 09:29 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
Graphic representation of firing order:
http://www.autozone.com/servlet/UiBr...3d80194f35.jsp
Old Oct 15, 2005 | 03:02 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
this is a big problem on the accel HEI's I had to make a huge guess where to put things, nothing is labeled! Luckily I got it on the first try. I should make a chart.
Old Oct 15, 2005 | 03:09 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Check out fig2 on that page, the 2.8L only runs on 5 jugs i guess
Old Oct 15, 2005 | 04:20 PM
zimmchile7's Avatar
Car: 1985 Trans Am
Engine: 383 Stroker
You said jugs, do you work on airplanes too? That's what we can cyl's on small airplanes.
Fanatic1074
Oct 3, 2022 05:57 AM
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Damon
Sep 26, 2015 04:29 PM
