Wont crank Help please
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Ok Got a brand new powermaster mini starter for when i put my longtubes in the starter has been in a week and today I got in the car it cranked over a little bit then it stopped and wouldent crank anymore then I turned key off then on and it started to crank by itself.
After that I push started it and made it to a friends house where I shut it off and tried to start it again, when i did that the starter gear didnt kick out but the motor started spinning and when i let the key out of crank position it kept cranking.
After a scurry to disconnect the battery I put the car in the air and inspected my electrical (expecting something to be melted on the headder) everything was fine so I charged the battery and now when I turn the key to crank all my lights go dim the starter maked a whining noise (doesent spin) and seems like it drains the batter instantly.
So I think the starter is shot.
any other info would be appreciated because I'm at a loss thanks
AL
AL
Car: 89 Formula
Ok thanks I'm calling them monday and I'm gonna bitch up a whirlwind
me and my friends were busting *** to get all our cars together to go to the track this weekend and my starter **** needless to say I'm pissed
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Though, when you say the motor was spinning but the gear didn't engage, did you have a peek see under the car and look at it visually while some one was cranking (or a starter interupt switch works too).
Often times, with a starter, one of the best things to do is to go under and see what's going on while it's actually trying to work.
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Something everybody over looks as well, Check your connections to ground, and to battery, on both the starter and the battery. just my
Car: 89 Formula
Only reason it gets me soo bad is that I drove it to where I was when it ****ed up
I had it on the battery charger and when i would try to start it it would make a terrible whining noise not turn the engine and it seemed to almost completely discharge the battery in a matter of about 5 seconds I'm confused
skinny z
Oct 5, 2015 06:23 PM
