Timing [again]
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Timing [again]
Well i could do with a base setting, as again the Haynes manual is as much use as an ashtray on a motorcycle.
My engines a 305, theres absolutely NO emmision gear [cat is in the bin] and single straight through exhaust pipe to the backbox.
I'm using a mallory HEI distributor [ 8548201C] with the matching coil and the vacumn advance is hooked up.
I know the idea is start with a base setting, and keep advancing till you hear it pinking then back it off.
All i need is an approximate starting point to try that wont be too retarded or too advanced.
Car: 91 RS
Engine: 305 Tbi (L03)
At idle it should be somewhere around 10 degrees btdc. You should also check timing at 3000-4000 rpm. Youll need a timing light with an adjustable advance. Id start at abou 28 or so in that range. That second measurment will give you your total timing.
Engine: 302
Axle/Gears: 3:73:1
Thanks, i will give that a try.
Despite having a Snap On timing light, its been a long time since its been used i can tell you, its a rare occasion to find a moveable dizzy. Actually found cobwebs inside the timing light case.
And why the manual is so obscure about a lot of things beats me.
