'89 L03 no start - VATS?
Old Oct 15, 2005 | 10:14 AM
Buck268's Avatar
Wrenchin on the '89 WS6 Formula (L03/700r4), trying to get her running.
Basically, battery is "good" (good enough anyways), all electrics seem to work, ign switch seems to work (acc., key off and key on engine off) just wont start at all. No cranking, no selinoid engaging, but the inst. cluster goes through the typical starting deal.
Actually, two lights light up that have me a little confused (haven't driven this car in a few years). First is the brake light, should that go off with my foot on the brake during engine starting, or does it always come on? Second is the security light. It lights up when I try to start, and I'm almost htinking its a problem with the VATS system, maybe even just a loose/broken wire. Unforutnately there is very little info on this system around.
Guess I'm asking really only 1 specific question. Assuming the vats doesnt get the proper signal needed (for whatever reason), how would the car react to a start-up attempt?
Old Oct 15, 2005 | 10:18 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Exactly like you said yours is acting.
Old Oct 15, 2005 | 10:21 AM
Buck268's Avatar
hmm, so I guess I need ot trouble shoot the VATS. Great.
Well first things first, test the wires/circuits. Really have never messed with this stuff before, but maybe somebody could point me towards some info on this system?
Old Oct 15, 2005 | 10:38 AM
Buck268's Avatar
Key is suspect, getting extremely high resistance through the "chip" (I know its just a resistor). Does anybody know what range it should be in, I'm aware there are a few different exact resistances.
Old Oct 15, 2005 | 12:11 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If you're going to temporarily wire a resistor into the VATS input, start off with a 1.5k. For some crazy reason, every thridgen I've seen has a 1.5k VATS key.
Old Oct 15, 2005 | 02:01 PM
Buck268's Avatar
Oddly enough, I got a second set of hands and got a better reading on the key chip. 7.48k, so I'm going to run two 3.9k (actual measured value of 3.82k and 3.81k ) in series for a total of about 7.8k; hopefully that is within the fault tolerance for the VATS decoder.
In any case, I did narrow it down to a switch-position sensitive VATS resistance issue, so I figure worst comes to worst I'll just have to tear down the steering column (which needs down anyways as the tilt is busted).
Old Oct 16, 2005 | 09:52 AM
Buck268's Avatar
VATS wires on ign. cylinder broke...
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
djmarch
Aug 19, 2015 12:07 PM
