question?
Old Oct 15, 2005 | 07:39 PM
350WHT's Avatar
Car: 1992 camaro RS
Engine: sbc 350
Transmission: th350
question?
ok i recently built a 302 for a 91 mustang my car keeps overheating its got a 160 thermo and a flex fan but theres no shroud on it but the fan is very very close to the raditor and the car still has all the factory air dams on it but i think the water pump may be turning the wrong way i got a water pump for a bronco and the pulleys are a serptine setup now does anyone now if a ford bronco around a 87 is a reverse flow cause i cant find it anywhere, i know the water pump is spinning backwards but i dont know if a frod broncos are supposed to. the guy at auto zone told me the bronco water pump would work so i put my car in his hands bascially which isnt a good idea.
Old Oct 15, 2005 | 07:45 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't know, but why didn't you get one for a 91 mustang?
Old Oct 15, 2005 | 08:09 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Wow, Mustangs, Broncos. Couldn't get much further off topic, could you?
Unless you mentioned the WP came from a T-Bird.
Heck, ya can't even spell Ford correctly.
Old Oct 15, 2005 | 08:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Old Oct 15, 2005 | 08:36 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
i believe it's the same water pump, are you sure it's overheating? Mustang's temp gauges aren't the most accurate. I'd definitely find a shroud or convert it to an electric fan. Probably not pulling enough air through it.
Old Oct 15, 2005 | 08:40 PM
Since I'm also a mustang fan here's a decent site that's relatively new about mustangs. Doesn't have all the Mustang Vs. F-body bull****.
http://www.mustang-forums.com/index.php?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
