Driving with a missing cylinder is it bad?
Old Nov 13, 2001 | 08:59 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
it is a 4 liter jeep motor, and the 1st cyl is miss fireing it clears up at high rpms. I think it is in the valves so am I doing damage by driving it? The truck is somthing that is only used to go in the woods move things and once in a while it is taken on long trips. The next few weeks it will probably get used alot.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 14, 2001 | 06:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not good.
If it's misfiring due to ignition, you're washing down the cylinder walls with raw gasoline - not a good lubricant.
If it's misfiring due to valves, you're leaking hot gas past the seats and burning material away from the valve or seat, or both.
If it's misfiring due to a lean mixture from a vacuum leak on that cylinder, you're running a hot mixture that can also do damage.
Whatever the cause, it really should be fixed.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Nov 15, 2001 | 06:19 AM
BLACK Z's Avatar
Car: 86 Z28
How can I figure out which one it is?
Old Nov 15, 2001 | 08:19 AM
firbird's Avatar
if it is ignition i would check to see if you have a spark, and if it is the valves you might wanna check the compression.
TheJoeY88
Dec 31, 2016 07:30 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
