help: now i cant get it started
Old Oct 16, 2005 | 02:13 PM
84camaroZ's Avatar
Car: 1984 Camaro Z28
Engine: LG4
Transmission: th-700
yesterday i put a new intake and carb on my camaro. this morning i finished hooking up the distributor, wires and fuel line. now it wont start. its cranks, sometimes it starts to turnover but then nothing i have pics of where i stand right now. my biggest prob is transfering all the emmisions trash.
Old Oct 16, 2005 | 02:25 PM
84camaroZ's Avatar
Engine: LG4
start and present
Attached Thumbnails help: now i cant get it started-untitled.jpg
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Did you turn the engine to #1 TDC firing and make the corresponding terminal (whatever the rotor is pointing to) the #1 wire?
Old Oct 16, 2005 | 02:41 PM
84camaroZ's Avatar
Engine: LG4
i marked the distributor housing before pulling it and dropped it back in in the same spot. the housing did get turned just a bit when i was putting the clamp back on. could this cause the problem?
Old Oct 16, 2005 | 03:19 PM
84camaroZ's Avatar
Engine: LG4
i got it started but its flooding itself every time. fuel is pouring out of the top. ive never seen this before.
Old Oct 16, 2005 | 03:27 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I don't know anything about working on carbs at all, but are you using a mechanical pump or an electrical one? Might want to check the fuel pressure.
As for the timing..do you have a timing light? You'll need one if you don't. Loosen the bolt on the hold down clamp and adjust the distributor clockwise or counterclockwise until it runs right. With a light, get it to 6* BTDC. If your car has a electronic spark control, there is an EST wire that needs to be disconnected first.
Old Oct 16, 2005 | 03:57 PM
84camaroZ's Avatar
Engine: LG4
all is good, think the floats were just stuck. tapped on it a bit, started it up and now its running clean. thanks for the help guys
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
