500 HP 383.....Should i use a catalytic conveter?
Old Oct 16, 2005 | 07:33 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I am building a close to 500 HP Super-Rammed 383 for my 89 GTA. I am wondering if a catalytic converter would be bad idea for this car. I know it is not a big deal when the motor is putting out 250 HP, but im putting out close to double that. My goal is to keep everything on the car that it came stock with, or replace it with a better part. For example, I still have A.I.R., EGR, A/C, but obviously i replaced my engine and transmission with higher performance internal pieces.
I want to keep the catalytic converter, but i think it would be way too restrictive. My exhaust set up includes SLP 1 3/4 headers with A.I.R., the y-pipe that comes with them, mandrel-bent 3 inch pipe to a flowmaster 80 series with dual 2 1/2 inch pipe out the back.
What do you guys think? I know that companies like Catco make "high flow cats", but high flow is relative.
Old Oct 16, 2005 | 08:59 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If your not subject to emmisions, then dont run it. Id say two 3" cats wouldnt be restrictive, but youll need to make sure the engine is rich enough to shut down the cats at WOT or theyll melt in a hurry. Also, a hot cam could potentially dump alot of air and fuel into the cats at low RPM operation, shortening their lifespan.
Old Oct 17, 2005 | 07:30 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Isn't that a little like saying "If no one is watching it is ok to steal?" Your not going to lose anything noticable if you use a Cat. Surely, nothing that your right foot/reaction time won't more than negate.
Old Oct 17, 2005 | 08:27 AM
Car: 88 Camaro SC
Engine: SFI'd 350
While good dual cats wont be a restriction, you have to be careful with them. Performance air/fuel ratios dont work well with cats. All the extra fuel mixed in with the residual oxygen will cause long term damage and possibly immediate destruction. Id defiatly prefer not to have it. You can run leaner, make more power, and not have to worry about reducing 150-300+ dollars worth of ceramic and precious metals to molten scrap. I have one with my 3" system. Its nice having the car run oderlessly and have clean emmisions, but I hate having to watch over it to prevent damage.
Old Oct 17, 2005 | 11:39 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I run a single 3in catco on my 383. I like the less smell and also the less raspyness with the cat.
PurelyPMD
May 5, 2016 04:57 PM
1992Z28!
Nov 19, 2015 07:33 AM
Eric-86sc
Sep 22, 2015 08:25 PM
m00n420
Sep 11, 2015 02:39 PM
89fast5oh
Sep 8, 2015 09:55 AM
