Belt & Pulley help needed!!!
Old Nov 15, 2001 | 05:35 PM
70GTO's Avatar
Car: 89 Iroc Z
Engine: Carburated 427 Smallblock
Transmission: 400 Turbo
I'm removing the tpi engine out of my 89 Camaro. The computer, smog pump, etc... is history. I'm going to keep the A/C and power steering. Do I stick with the serpentene belt system and stock aluminum mounting brackets, and if so what do I do about the void left by the smog air pump??? Or is it better to switch over to a V belt system, If so where is a source of suppliers tho get the parts to make the switch from???
I'm planning on using the existing alternator and A/C compressor are there any problems associated with using them if I go with a V type belt. I know many people out there have already done this and I would really appreciate your advice on what kind of setup you ended up using.
Thanks in advance, Bruce
"Four on the floor, fifth in the glove compartment"
Old Nov 15, 2001 | 05:47 PM
Joshua Leslie's Avatar
which heads are u using? the heads from the T.P.I? or older pre 86?
I did the swap from my 89, and left everything.
The heads were fromt he 70s.
The only problem was that 2 of the mounting bolts didnt go back in, cuz the heads didnt have holes for them. but ive put a few thousand miles on it, and havent had any problems.
just leave the smog pump in, and remove all the hoses that come off of it.
Old Nov 15, 2001 | 06:37 PM
Guest
Guest
Posts: n/a
So you are gonna have AC, PS, Alt (I hope), and water pump (I hope).
Look here:
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Nov 15, 2001 | 07:20 PM
70GTO's Avatar
Car: 89 Iroc Z
Yea, an alternator and water pump too. (I figured someone would think i was getting smart if I listed them). It's a dart little M block w/Brodix heads.
Old Nov 15, 2001 | 07:30 PM
70GTO's Avatar
Car: 89 Iroc Z
Madmax, Thanks for the link to the article. It takes a hell of a load off of my mind knowing how to accomplish the task and that I dont need to buy any more aftermarket parts. (the engine project has pretty much exhausted all of my funds)!!!!
"The project Small Block 427 is underway"
IROCZ1989
Jan 24, 2016 03:55 PM
Navy8125
Aug 22, 2015 07:13 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
