Need help with power steering bracket configuration on 86 TA! Immediate help needed!
Old Nov 15, 2001 | 06:00 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm finishing up my engine install and trying to get the power steering pump put back on. Problem is... I can't figure out the configuration of the bracket. This car is a 1986 Trans Am... before the serpentine assembly. The AC and the power steering use the same bracket(s). There's like 3 pieces to this bracket. The AC has been delted but that isn't helping any. One problem I see is that one piece of the bracket attached to the old manifold and well, I've got headers on there now. Help ASAP would be greatly appreciated. Pics... anything. Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 15, 2001 | 07:25 PM
Vader's Avatar
86,
If you want a photo(s), just tell me what angles you would need. I'll send you some. Also indicate what format you prefer (jpg, tif, gif, bmp, whatever).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 15, 2001 | 08:21 PM
<font face="Verdana, Arial" size="2">Originally posted by Vader:
86,
</font>
I figured you'd reply Vader, beings you have an 86. I appreciate that. I've fixed the problem though. I now have a hybrid power steering bracket... half power steering bracket/half smog pump bracket. Hey, it works. The problem I was having is that the part of the bracket on the far drivers side originally bolted to the manifolds.. well, I added headers and that bracket no longer would fit. It's all good now. Thanks Vader.
1986 Trans AM
305 TPI
4 Wheel Discs
Completely Stock
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
