Vacume leak?
Old Nov 15, 2001 | 10:12 PM
Trent257's Avatar
Vacume leak?
ok, i ahve a vaccum leak somewhere, the line that goes from the manifold to the stock air cleaner i took off when i put on my open element, could that be it, should i plug it up??? i also broke a small plastic line going to the intake or tbi, how can i fix that????
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 16, 2001 | 04:31 AM
Jza's Avatar
Jza
Yes, you should plug the port on the throttle body that used to connect to the air cleaner. That is a definite vac. leak.
To fix the plastic line you broke, you'll have to pick up some from an auto parts store. If they don't have the plastic type, you'll have to use a rubber line, just try to get the size closest (inner diameter) to the broken plastic one. Sometimes, if the plastic isn't too brittle, you can use a short length of rubber hose to connect the two ends of the plastic line where they broke.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
