305 or 350? Which do I have?!
Old Oct 18, 2005 | 04:24 AM
Tarnel's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A4
Ok, so I purchased a 91 Camaro RS about 2 weeks ago and was wondering if it was possible that the engine could have been swaped for a 350? If so, what are some signs to look for that allow you to tell the difference between a 305 and 350? Is the 350 bigger? Maybe some design differences that are easy to tell?
Codes or ID numbers? Just curious cause I have RS badges but a Z28 hood. The VIN says I have a 305. Im pretty sure I have a 305 cause theres still stock intake and exaust.
Thanks,
-Tarnel
Old Oct 18, 2005 | 04:41 AM
Camaero's Avatar
Car: 1987 IROC Z/28 Camaro
Engine: 355
Axle/Gears: 9 Bolt w/ 4.10s
I had this problem recently. This helped me:
https://www.thirdgen.org/techbb2/sho...hreadid=325848
Old Oct 18, 2005 | 04:54 AM
Tarnel's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A4
Thanks for the help, Ill go bust out the headlamp and take a look! =)
-Tarnel
Old Oct 18, 2005 | 04:57 AM
Camaero's Avatar
Engine: 355
Now I have a California car and had smog crap up the whazoo. I could not for the life of me get those numbers behind the valve covers. (And I knew right where they were from past experience.)
I had to crawl under my car and look for those 3 large numbers. They were very easy to spot and very clear. If you have problems, I would suggest to jack your car up and take a look.
Cheers and good luck!
Old Oct 18, 2005 | 08:19 PM
mantiz85ws6's Avatar
Car: 85 Trans Am
Engine: 350 T.P.I.
Transmission: WC T-5
What would casting number underneath middle of block either 703 or 307 translate too?? Anyone know
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
