Putting the Cataletic Converter back on
Old Nov 15, 2001 | 09:09 PM
DiecastZ28's Avatar
I just bought my first car. '85 Z28. Got it for 1200. Its one of the best camaros around but it doesnt have cat on it. The kid cut it off because "it wasn't loud enough." Anyways, I was just wondering how much HP I will lose when I put it back. Its about 2 to 2 1/2 feet long. My sisters boyfriend said if its that big it wont lose any... I know I should belive him since he is an excellent machanic and is one of the highest paid around here.. Also how much quiter will it be?
1985 Camaro Z28
305
Manual Tranny
Light Blue
Flowmaster Exhaust
4 barrel carb
8mm racing spark plug wires
Old Nov 15, 2001 | 09:40 PM
82camaro's Avatar
Car: 82 camaro SC
It will be quieter, but that depends on the cat you put on it. The power reduction also depends on what cat you use. If you have a fairly restrictive muffler, the cat won't hurt power much. Why do you want the cat back on?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 15, 2001 | 09:41 PM
Joshua Leslie's Avatar
there was an article about this in Hot Rod...at least I think it was hot rod, and when they pulled the catalytic converter the car actually made 2 horsepower less than putting a high flow converter on.
Old Nov 16, 2001 | 02:26 PM
DiecastZ28's Avatar
I have to put that cat back on because I have to pass emissions in MA which really sux, because belive me, the car sounds hot. By the way i have a Flowmaster Exhaust, im guessing 80 series.
1985 Camaro Z28
305
5-speed Manual Tranny
Light Blue
Flowmaster Exhaust
4 barrel carb
1992 Trans Am
May 10, 2023 07:19 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
gwade12
Aug 8, 2015 08:17 AM
