gas problem and smell
Old Oct 18, 2005 | 09:45 PM
bigd25x's Avatar
Car: 92 Camaro RS TTops
Engine: V8 TBI
Transmission: th700-r4
well ive been over this a few times, but i know alot more now.
cars a 92 camaro rs w/ the stock 305 tbi engine, im geting around 9mpg (about) it used to be alot better, stock manifolds going into cat back to flowmaster. it smeels like stright up unburnt gas VERY VERY BAD. my tbi has been cleaned, i got a new fuel filter havent put it on yet, i changed out the plugs. the wires\cap look pretty new.
the car takes time to start like i have to like it turn over for a good 5-6 secounds or 2 secounds let off and 2 secounds more. sometimes harder.
so im beleaveing this is a timeing problem? this is my daily driver so i gotta get it fixed fast cause im going on trip this weekend, even tho the cars for sale i still gotta fix it.
ANY IDEAS, PLEASE POST ASAP!
thanks ALOT you guys rock
Old Oct 19, 2005 | 06:29 AM
michta's Avatar
Car: 1984 ta slightly modified
Transmission: auto 350 w/reverse valve body
Axle/Gears: 410 ratio
Check the oil for gas in it, Also what about the fuel pressure regulator? Too much fuel will cause numerous problems on these cars.
Old Oct 19, 2005 | 09:34 PM
bigd25x's Avatar
Engine: V8 TBI
ill check oil tomarorw, i need somemore info on the fuel presure. todayi went about 60miles. it was PERFECT on gas like 20mpg or so, but like city i driveing i get like 9!!!!
Old Oct 24, 2005 | 10:46 PM
bigd25x's Avatar
Engine: V8 TBI
any ideas?
Old Nov 2, 2005 | 03:48 PM
bigd25x's Avatar
Engine: V8 TBI
BUMP!!!! PLEASE !!
Old Nov 3, 2005 | 08:13 AM
It is not the timing. Timing will not cause excessive fuel delivery.
Probably not the EGR either. Same reason.
Now that we have the 2 universal things off the table that people always want to blame for any kind of driveability problem, it's time to get serious.
You have too much fuel getting delivered. Don't grasp at straws, instead, concentrate your efforts toward things can can deliver too much fuel.
Have you replaced the O2 sensor? That should be a part of a tune-up. Also, put a cap & rotor in it, it's kind of pointless to try to troubleshoot something when some of the parts that are both cheapest and most likely to fail, are old and worn.
Start there, see if it makes a difference.
If it doesn't, I'd be looking at the injectors next. They're easy to get at the junkyard.
bryan623
Mar 22, 2021 06:43 PM
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
wayshegoes
Aug 17, 2015 12:00 PM
