Another Temp Question
Old Nov 17, 2001 | 09:18 AM
PopaPork's Avatar
A few weeks ago I put a post up about my TEMP Gauge. The stupid thing was gettin stuck up on the top part of the gauge. Well I finally got the time to get the pin off the side of the gauge side. Now the stupid thing doesnt move. The pin sits at 0 all the time. The only time I noticed any change was yesterday it went from 0 to maybe 100 degrees and that took about 5 hours of driving (Rochester NY to Trenton NJ) Any one got any ideas? I checked the connection on the block and it was on, and when I checked the pin when I had the gauge out all seemed fine. So I am pretty stumped. Thanks
1989 RS Camaro
305ci TBI
Mods:
Hedman Header
Highflow Cat
3inch catback pipe
FlowMaster 80 Series Muffler
14x3 Open Air Element
8.5 HighTemp Spark Plug Wires
4.7 Ohm Reistor
Torque Converter Lock Up switch
www.rit.edu/~cjp8408
AIM: PopaPork
Old Nov 17, 2001 | 01:07 PM
z28onTweenkies's Avatar
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
Do what i did, i replaced the cts connector which is the two wire harness that plugs into the cts on the coolant passover. After i had changed that all was well. My code 15 disappeared and the temperature read correctly. Hope this helps, by the way, a new cts connector runs about 20 dollars at the dealer.
1987 LG4 Camaro z28
Modifications- Flowmaster 80 series, KN airfilter, high flow cat, 180* stat, edelbrock performer intake manifold, msd blaster coil, ascd big block hood, panasonic cd player, rockford everything else.
Bstrang6
Sep 8, 2015 04:29 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Irocohio
Aug 12, 2015 08:03 AM
