Bent a pushrod
Car: 1991 camaro RS
Engine: 305 Carb
Bent a pushrod
well, i have ben haveing trouble getting valve lash adjusted properly, i pulled the cover off and adjusted the valves, then found out that i have them extremely too tight, so tight that i bent a pushrod. I used the method where you look at one set of valve on any cylinder, turn to engine till the exhaust valve begin to open, then adjust that intake valve. It seemed like a pretty good method, but after i adjusted that intake valve, i would bump the engine over again and the that intake valve would be loose again, like say when that exhaust valve was at maximum lift. So im haveing a really hard time getting them adjusted, so i think what im gonna do is try it with the engine running.
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I followed what the book said and I had 0 problems, i didnt have to adjust them at all, one time and thats it.
Bring piston 1 to TDC and follow the guide on which ones to tighten, then turn motor over 180* and do the rest.
I had about 4 threads from the top of the bolt to the top of the stud showing if that helps at all.
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Originally posted by del91_305
Well, only problem is, i have a hard time finding top dead center.
Car: 1992 Firebird
Engine: forged 357
Wasnt thinking, ill give this method a try
Wasnt thinking, ill give this method a try I did it the same way (like the book said), before I realized I made the situation worse. I asked a competent mechanic, and was told to adjust this way:
have someone in the car holding the idle up to aroun 1500rpm while, with the valve covers off (vacuum lines plugged and towels to soak up the oil that will squirt out), adjust each rocker nut outward until you really feel the valve tap and then adjust it back in 1/4 turn. Do all valves quickly, then shut off the engine, hook everything up, and there you go. You can do a quick manifold vacuum test to check it overal real fast if you wanted to.
