bolt pattern? 5x4.5"?
Old Nov 16, 2001 | 05:11 PM
RARE-ROC-Z's Avatar
is that the bolt pattern for camaros, firebirds, S10s and stuff?
because if so.. camaro wheels will fit on my JEEP GRAND CHEROKEE.
thanks
Jarrad
United States ARMY Military Police Officer 339th Division
formerly owned:
1990 IROC-Z L98
Old Nov 16, 2001 | 05:36 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
only on the rear.the front has zero offset,i believe
Old Nov 16, 2001 | 11:04 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
OOPPSS. Double whammy!!!
AJ
[This message has been edited by AJ_92RS (edited November 16, 2001).]
AJ_92RS's Avatar
The bolt pattern is 5 x 4.75 on 'almost' all rear wheel drive cars & the S-10. The Caprice has a 5 x 5" bolt pattern like the trucks.
The way to measure the bolt pattern size on any odd # of studs (5, 7, or 9 for ex.) is to measure from the middle of one to the opposite other, but using the outside edge of the opposite one.
The real way that they measure the distance is the true diameter of the circle which is formed by following the center of the studs. Kinda like a faucet on a sink. Since there are no studs directly opposite of each other on odd # studs, then using that outside edge is the next best thing.
If you want you can draw a cirle on the wheel and measure it that way, but that's too much like work.
..............A
..............O
........O.........O
..........O......O
.................B
From center of "A" to outside edge of "B"
AJ
Old Nov 17, 2001 | 03:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 5-on-4.5" pattern is the F*rd and Chrysler pattern. The GM pattern for passenger cars is 5-on-4.76", except for some of the large cars as noted above, which use the standard GM truck pattern of 5-on-5".
So, Camaro wheels will not go on a Jeep.
ICON Motorsports
Old Nov 17, 2001 | 06:45 PM
AJ_92RS's Avatar
Ya know. I meant to put the "GM" in front of "cars".
Sorry.
AJ
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
