keep throwing/breaking serpentine belt
Old Oct 21, 2005 | 07:23 AM
antmonty's Avatar
Car: 91 1le
I keep breaking the belt on my 91Z 305 after about 2 months. All the pulleys look fine. I don't hear any squealing, it usually just breaks. What could be causing this?
Old Oct 21, 2005 | 08:07 AM
R1UK's Avatar
Car: Was 3rd Gen now MustangGT
Engine: 302
Axle/Gears: 3:73:1
Check the crank [as well as others] thoroughly, when i find this on cars here, it can be coz some heavy hander has wacked a chunk off the crank pulley and damaged the multigroove pulley.
Thus putting a sharp edge on it, which in turn saws through the belt, or deflects it off.
Or your tensioner might be running out of line, check the tension is good enough to keep the belt tight, and make sure its inline with the other pulleys, if not it can deflect the belt off.
You might need an assistant to crank the belt tensioner back and forth while you check it, its a bit safer.
Old Oct 21, 2005 | 10:20 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
If you're breaking belts it seems like it is a damaged/misaligned pulley. If you were simply throwing them, I'd say a seizing accessory.
Old Oct 21, 2005 | 10:00 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
My truck was going through belts and it turned out the be the idler pulley. It was slightly worn at an angle.
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
