removing broken bolts
Old Oct 21, 2005 | 03:56 PM
grumpyvette's Avatar
http://www.freealloil.com/freealloil/freeall.html
http://www.crustyquinns.com/tech/easyout.html
http://www.asashop.org/autoinc/may2003/techtotech.cfm
if you can drill thru the center of the broken bolt with a bit aproximately 2/3 the dia of the broken bolt, untill the bit goes ALL the way thru then soak the $%^ out of it with FREEALL penetrating oil,(this stuffs amazing) this will allow the oil to soak in from both ends of the broken threaded section, let it soak at least 30 minute while you re-apply more spray oil every few minutes, then insert the easy out and gently twist the broken bolt remains out of the threaded hole, BTW heating and cooling the bolt, helps. heat with a propane torch the cooling it with the spray oil helps to lossen its grip on the threads if its really stuck :grin:
Old Oct 21, 2005 | 04:39 PM
Okay how about tricks for keeping them from turning into the rusted ready to snap pieces of junk, in the first place?"
use grade 8 stainless and a coat of ANTISEIZE paste on the threads durringg assembly tends to prevent the problem
http://www.jegs.com/webapp/wcs/store...tegoryId=22449
Old Nov 5, 2005 | 05:57 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Move to the southwest where its so dry that 50 yo cars practically fall apart.
Antiseize helps in certain situations but with the salt they put on the roads in the winter here in the midwest, it seems like nothing can prevent rust.
Old Nov 5, 2005 | 06:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
graded bolts are only for steel bolts. allen bolts are generally grade 9, and stainless are in a class of themselves, somewhere close to a grade ~4 (if that existed..) IIRC.
but good tips, thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Eric-86sc
Apr 3, 2016 03:52 PM
3rdgenparts
Aug 8, 2015 07:09 PM
