Stripped distributor gear, what to do????
Old Nov 18, 2001 | 01:38 PM
Arntzman's Avatar
I just finished my 305 to 350 swap. When I went for the test drive, the car stumbled, backfired and shut-off. Afterward it wouldn't start. AFter looking for causes of the problem, I found out that the gear on the distributor shaft has about 4 teeth sheared off and all of the other teeth are worn about 2/3 of the way through. From what I can tell the camshaft looks alright.
I have a high volume oil pump. My camshaft is a flat-tappet hydraulic Competition Cams Xtreme Energy camshaft. I know that you have to change distributor gears when running a roller cam, but didn't think you had to switch the gears for a standard hydraulic camshaft. Will getting a bronze gear solve my problems?
Thanks,Dave
Better to keep one's mouth closed and be thought a fool, than to open
it and remove all doubt.(Mark Twain)
Homepage of VTCamaro/Arntzman
Need Wiring Diagrams??
darntz@vt.edu
Old Nov 18, 2001 | 01:55 PM
SoCo80p's Avatar
dont run a bronze on it, most likely just from age and the high volume pump puts a bit more strain on the gear and was just a little too much for it, just get another (new) steel gear and you will be fine
Old Nov 18, 2001 | 02:12 PM
dragcamaro's Avatar
hey man,.. I had the same thing happen on my 409 sb in my '80,.. I was running a new hydraulic roller camfrom comp cams,.. it was a CAST cam, not billet, so I ran the steel gear. I had the same things you did, jumping timing, ran rich too . Pulled the dist out,.. all teeth were thin and like one side was worn off. I replaced it with a bronze one, had no problems since. Comp cams and a few reputable engine builders had no idea why it did it,....just a freaky thing I guess. The dist. was rebushed and endplay set prior to the first installation. Hope any of this can help!
1980 Camaro- (sub) frame off resto, my drag car
1985 Z-28 - My newest toy and driver
1967 Camar - to be purchased SOON!!
Old Nov 18, 2001 | 03:42 PM
Arntzman's Avatar
So, will running a bronze gear hurt anything, such as the camshaft?
-Dave
Old Nov 18, 2001 | 04:15 PM
SoCo80p's Avatar
no but you have to change them about every 3,000 miles
Old Nov 18, 2001 | 06:29 PM
iroc5speed's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
no but you have to change them about every 3,000 miles</font>
I've never heard that, there;s no way it would only last that long.
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
